do I need to redownload survey 123 connect to have these different form preview? I can not find where on my form preview it would allow me to change from he basic one I have.
Hi Todd,
I just downloaded and installed Survey123 Connect v3.5.157 and can see the form preview options at the below the form. You can download the latest version of the Survey123 Connect for ArcGIS from this link.
https://www.esri.com/en-us/arcgis/products/survey123/resources
To upgrade your Survey123 Connect, uninstall the older version and install the new version. This won't affect any of your forms so no danger of losing any of your hard work. Still might not be a bad idea to backup any forms anyway just in case 🙂
Thank you for sending me this, it works great on my desktop, but will not
open on my laptop. I get an error every time
If I hit yes then after a couple of step this error comes up.
Help.
Thank you,
Todd Ackerman
775.901.0936
It sounds like there are some files and folders left behind when you tried to uninstall the application. It could be that you had the application open or something was locking the files.
Can you go to the installation folder "C:\Users\{username}\Applications\ArcGIS\Survey123ConnectforArcGIS" and ensure this entire "Survey123ConnectforArcGIS" folder is deleted.
Try and install the Connect application again after this folder no longer exists.
Regards,
Phil.
Philip
Thank you, that did it!!
Todd
