Hi Guys,
This is the screenshot of the error that i'm getting while submitting the survey form to ArcGIS Online. I've used so many nvarchar values 'Yes'. I haven't been able to find which one is causing the error. (I have attached the xls form too)
Hi Imran,
You've forced a lot of the select_one questions to be of fieldtype 'esriFieldTypeInteger' when they should be 'esriFieldTypeString' or left empty - this is what was causing the error in the app,
You might want to also look at your choices sheet and the Name coloumn. A lot of the answers contain spaces or characters not accepted by Survey123 and some of the answers exceed 32 characters.
Carmel
