I have a survey - the web form gives me this strange error, that I do not see anywhere or any documentation on. thoughts? is it because of the pages?
the survey link opens fine in survey123, just the web form gives this strange error...
https://arcg.is/15Cb04
attached is error and excel sheet...
Hi Aurelie,
The error you are getting is because you are using property('deviceid') which is not supported in the web app. Here is a list of the supported pulldata() properties and the correct syntax to use in a calculation: Prepopulate answers—Survey123 for ArcGIS | ArcGIS
Phil.
