I use Survey 123 Web to create my surveys. I published the survey and it has been used once to collect data. The data collectors want to make changes to the survey for the next time they use it but I know that I have to create a copy of the survey if I want to make changes. My only concern is that the data will not be together from the original version and the copy version. Can someone tell me if this is true or does the data get separated when you make a copy?
