When I create a new survey and publish it to ArcGIS online, I am able to edit repeats in that survey [after it has been submitted]. However, when I publish a feature service from ArcMap to ArcGIS online (we do this through ArcGIS Rest API), I am unable to edit repeats in the submitted survey. In other words, surveys with hosted feature layers on ArcGIS online allow edits to repeats on submitted surveys. If the feature layer is not hosted in ArcGIS online, I am unable to edit submitted surveys with repeats. Is this a known restriction or bug for Survey123? This survey must be completed through the web, not the app.
Here are some examples below:
Below is the error message I receive when I try to edit repeats on a submitted survey that is not a hosted feature service
When I create and publish a survey from an existing feature service, it creates a folder containing a web map and the survey form. This is the one I am not able to edit repeats on.
For this survey, I am able to edit repeats after it has been submitted. This was created from a new survey.
Thank you
-Abby
