I am doing an external select for several attributes, then concatenating them into a unique ID for a pulldata operation. The values are coming in with 1 decimal place instead of integer and I am unable to enforce integer.
Example: select_one_external dpas
I have tried both esriFieldTypeString and esriFieldTypeInteger in the bind::esri:fieldType column, to no avail. See attached for screen shots and spreadsheet.
Thanks.
Bob
Hi Bob -
Thanks for asking your questions and welcome to the GeoNet community! I wanted to let you know that we're moving your question to the https://community.esri.com/groups/survey123?sr=search&searchId=c6e047d3-3c13-466c-8424-caa86f0e4913&searchIndex=0 space so our Esri and user subject matter experts can further help answer this and future questions. So you're aware on how and where to post your questions, here's a few quick tips and reminders:
Thanks again for contributing and I hope this helps and let us know if you have any questions.
Hi Bob,
This is a known issue with using numeric values as labels in select questions at this time.
