and, when revising the change, this error persists.
Hi Josef,
I'm unsure about what error you are experiencing. Is this happening on an attempt to submit a survey record with Survey123? Republishing a form with Survey123 Connect?
Thanks for getting back to me! No records have been submitted yet, I was attempting to re-publish the survey after a minor edit (browser version, not Connect).
Josef
Von: James Tedrick <geonet@esri.com>
Gesendet: Donnerstag, 30. August 2018 01:11
An: Strobl Josef <Josef.Strobl@sbg.ac.at>
Betreff: Re: - Re: Without a major change to an existing survey, after text edit cannot be published "The file exceeds the max. size 1,000KB"
GeoNet <https://community.esri.com/?et=watches.email.thread>
reply from James Tedrick<https://community.esri.com/people/JTedrick-esristaff?et=watches.email.thread> in Survey123 for ArcGIS - View the full discussion<https://community.esri.com/message/795809-re-without-a-major-change-to-an-existing-survey-after-text-edit-cannot-be-published-the-file-exceeds-the-max-size-1000kb?commentID=795809&et=watches.email.thread#comment-795809>
For the web designer, the error message should occur when there's a hosted online image referenced in your survey is larger than 1 MB, such as in survey header/description or note question.
Can you please check the file size for each image you referenced in the survey? Just remove or replace those images with a smaller one (< 1MB) could fix the issue.
Thanks! I have already removed all images, unfortunately the error persists (even when copying the entire survey)
Regards, js
Von: Zhifang Wang <geonet@esri.com>
Gesendet: Donnerstag, 30. August 2018 19:33
reply from Zhifang Wang<https://community.esri.com/people/ZWang-esristaff?et=watches.email.thread> in Survey123 for ArcGIS - View the full discussion<https://community.esri.com/message/795978-re-without-a-major-change-to-an-existing-survey-after-text-edit-cannot-be-published-the-file-exceeds-the-max-size-1000kb?commentID=795978&et=watches.email.thread#comment-795978>
