Hello,
I tried to copy a feature layer into the spatiotemporal DS via the "Copy to Data Store"-Tool. I always get an error (either trying to copy it to the spatiotemporal or relational DS):
Start Time: Mittwoch, 4. April 2018 15:51:00
Running script CopyToDataStore...
Failed script Copy To Data Store...
File "c:\program files\arcgis\pro\Resources\ArcToolbox\Scripts\copytodatastore.py", line 32, in <module>
ga = GeospatialAnalysisTasks(analysis_type)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcToolbox\Scripts\gautils\utilities.py", line 16, in __call__
return self.func(*args, **kwargs)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcToolbox\Scripts\geoanalyticssoap.py", line 31, in __init__
self.token = auth_params.get("token")
AttributeError: 'NoneType' object has no attribute 'get'
Failed to execute (CopyToDataStore).
Failed at Mittwoch, 4. April 2018 15:51:00 (Elapsed Time: 0,05 seconds)
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Any idea what's wrong with the tool?
BR,
Carsten
