When editing offline, the user tries to click on the polygons to edit and it will not select the features. It will only let you select certain polygons but not all of them. Russell Roberts
If the map is offline line, you should be able to select all features that have a popup enabled. You cannot select features that appear in a tiled layer.
Russ
The popup is enabled and we are not using a tiled layer. It works on android and iphone , but does not work on ipad ios 8.2 and ipad ios 8.1.3.
Can you share the map with Collector4ArcGIS and I can take a look at it.
Thanks
Map is shared. Thank you!
Can you change the transparency fill on the polygons to something like 95% and let me know if that fixes the issue? If you tap on the borders of the polygons the popups are displayed so its making me think that maybe the fill of the polygon could be the issue.
