Hi-
I'm wondering if it's possible to click on a map either from Field Maps or a map in Survey123 that would then prepopulate certain questions? I have done some research and tried this: pulldata("@layer", "getValueAt", "attributes.NEW_MH_ID", "https://services7.arcgis.com/nZUcF2JydS8L5n3y/arcgis/rest/services/FSDMH/FeatureServer/2",${location}) but it's not functioning for me the way I would like. And not sure if this can only be used for polygon layers as the layer I'm wanting is a point layer. I had also tried creating a url that goes into the pop-up so when they click on the manhole it then should take them to survey123, but when I test it out it doesn't open the survey. If someone could tell me what i might be doing wrong that would be great!
Here is the code for the popup url which was generated through GitHub: <a href="arcgis-survey123://?itemID=0f782ed1a0de433b97092951c1038447&field:manhole_id={NEW_MH_ID}&field:manhole_depth={Z}"><img src="https://dabuttonfactory.com/button.png?t=MH+Survey&f=Roboto-Bold&ts=24&tc=fff&tshs=1&tshc=000&hp=20&vp=8&c=5&bgt=gradient&bgc=6aa84f&ebgc=274e13&shs=1&shc=444&sho=s" alt="MH Survey"></a>
This page walks you though it
https://doc.arcgis.com/en/survey123/get-started/integratewithotherapps.htm
This one is good toohttps://doc.arcgis.com/en/survey123/get-started/integrate-launchfieldapp.htm
This was the document I had originally referred to:
https://community.esri.com/t5/arcgis-survey123-blog/understanding-survey123-s-custom-url-scheme/ba-p/900291
But when I followed these steps and click the link in the pop up I get an untitled/about blank web page. Nothing opens up. This was the original URL:
"arcgis-survey123://?itemID=0f782ed1a0de433b97092951c1038447&field:manhole_id={NEW_MH_ID}&field:manhole_depth={Z}" before I found this blog:
https://community.esri.com/t5/arcgis-survey123-questions/announcing-a-handy-tool-to-generate-survey123-urls/td-p/782658
The documents you sent me pretty much state similar things and this where I'm struggling getting it to actually function as these documents state.
Are you wanting a web browser or app to open? Is this on a tablet or windows? Opening the windows app does not usually work but someone posted it recently they got it to go.
Well I'm building this out on a web browser but in the end it will be used on an ipad.
Ok the arcgis-survey123://? part says launch an app so its not going to work in Windows. To open web browser it has to start with the http way (https://survey123.arcgis.app). Best thing is to test on a tablet really. Otherwise change to the http to test but it does not tell you as much. Basically you are telling windows to launch an app you don't have. I know the directions sound like it may work but it does not. You can try getting the windows app but I have had no luck with that. (note NOT connect but just the 123 app for windows).
Hope that makes sense
it did have those "amp;" in them. I did remove them but still not prepopulating those questions in survey123. I am using survey123 connect to make any edits to the survery. Yeah i did see that it said for app, so i am now testing it through the ipad.
This is what it calls out in the pop up: arcgis-survey123://?itemID=0f782ed1a0de433b97092951c1038447&field:manhole_id={NEW_MH_ID}&field:manhole_depth={Z}
When i select a MH in field maps this url does replace the {PointID}s with the associated attributes, but when i click it and it takes me to the survey it does not show them in questions i called out. Maybe I have the type or something set incorrectly in the form that's preventing this? (I'm still pretty green to building surveys)
