Hello,I have been trying to find ways to keep a table I am using for my report template from repeating in the final template outcome. I tried using the $<summary> and $</> to close the table off on its' own page but every time I do this, it gives me a parsing syntax error that goes away once removed. Any ideas or thoughts would be greatly appreciated thank you. The table does contain two fields that are dynamic [$Project_Identifier and $Project_Name] that I need to use within the table that get the parsing error with the above summary syntax added on the page.
Hi @MathewBrown ,
Thanks for sharing here. If you put your table within $<summary> and $</>, you may need to use ${layerName | stats:"first, Project_Identifier"} to replace ${Project_Identifier}. The same applies to ${Project_Name}.
Here is the documentation for the report summary section: https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereportqueries.htm#ESRI_SECTION1_B8EE6E41851345079FF5D9D4D69AD1D3
Ruth
Thanks again for the reply. Unfortunately it still seems to be recurring again.
