Hello, I am a regular user of survey123 connect in ArcGIS Online, for a few days now I notice that when publishing surveys the hosted feature layer view of the form is being created, someone knows if this is a new configuration or how can I change it so that this publish does not generate this view for me.
This is used to handle the Collaborate tab settings in My Surveys.
I do not think you can get rid of it.
Yeh I experienced the same when Survey123 Connect seemed to update itself. It seems this _form view will always get created for Connect version 3.22 and later. Not ideal if you have a organisational workflow already set up. Survey123 _form hosted feature layer view - Esri Community
You do not have to use them its all used by the 123 website. They used to only create when you went to the 123 site but now seem to right away.
Thank very much for the information, I have been searching for and announce o something from ESRI.
