Hi, I am using Survey123 Connect. In an existing XLS Form, I made one change, I added a default value to a select_one question. I saved the form. When I went to publish the survey, I was greeted with the 401 message. I canceled the process.
I then pressed Publish again, and was greeted with this message, A-OK to publish. I canceled the process.
I clicked Publish again and was greeted with the 401 message. I tried this a few more times and watched the messages toggle between 401 and it's OK to publish.
If I remove the default value, save the form, and go to Publish, I get the same toggling behavior. If I am in the 401 message pane, and accept the warning and publish, I will wipe out 600 collected data points.
The form version is 3.19, 27 February 2024. I signed out of 123 Connect, closed Connect, reopened and signed in, same behavior. I did not reboot my laptop.
Any ideas on why this is happening, and how to prevent it? Thanks in advance, Jay
