ArcGIS Pro 3.4.2: The pop-up does not appear when clicking a particular cell on a raster,
I couldn’t figure out why the pop-up does not appear when clicking a particular cell on a raster
Is this a bug?
Setting the coordinate system of the imagery to “Unknown” appears to resolve the issue where the pop-up successfully retrieves the cell values.
Tha data is attached
its because the image is outside of the worlds boundaries as you can see from the coordinates below,i tried georeferencing it back to any basemap boundary and the pop up worked fine on both 3.4.2 and 3.0.2
This is likely a bug in 3.4.2, as it works fine in previous versions such as 3.1.5.
some "Ideas"
Add old pixel inspector to arcgis pro - Esri Community
Configure pop-ups—ArcGIS Pro | Documentation
Note:3D tile layers and some raster types do not support pop-up configuration.
and
A default pop-up consists of a single column listing of fields.
Suggesting that floating point rasters will not have default popups since there are no fields because floating point rasters have no table
