Survey is opening in 'edit' mode but not in 'view' mode. In view mode I get the message 'you do not have permission to view this record'. What do I need to change in settings to make the link accessible in view mode?
1. edit mode link that opens - https://survey123.arcgis.com/share/a3fa5ab0290246308c9c15b0bbc5dd8f?mode=edit&globalId=6e7585ef-953c-4495-8630-e19af1fcaea5
2. view mode link not opening - https://survey123.arcgis.com/share/a3fa5ab0290246308c9c15b0bbc5dd8f?mode=view&globalId=6e7585ef-953c-4495-8630-e19af1fcaea5
Check the settings at https://survey123.arcgis.com/ then Collaborate tab
Submitters have automatic read access. I do not see any other setting for read access/ viewing.
And these
Thanks Doug! not sure how I missed that tab. I can't seem to save a view access though. It shows the below error
text is copied below -
{"error":{"name":"ArcGISRequestError","message":"Service name 'survey123_a3fa5ab0290246308c9c15b0bbc5dd8f_results' already exists for 'PuB3FWUAxkScvfQy'","originalMessage":"Service name 'survey123_a3fa5ab0290246308c9c15b0bbc5dd8f_results' already exists for 'PuB3FWUAxkScvfQy'","code":"UNKNOWN_ERROR_CODE","response":{"success":false,"error":{"message":"Service name 'survey123_a3fa5ab0290246308c9c15b0bbc5dd8f_results' already exists for 'PuB3FWUAxkScvfQy'"},"isView":true},"url":"https://www.arcgis.com/sharing/rest/content/users/AW_Benchmarking/adcca14cd09f40b996736dbaebf4f22f/createService","options":{"httpMethod":"POST","authentication":{"username":"AW_Benchmarking","token":"3NKHt6i2urmWtqOuugvr9UyMtZ0i1U2oY05u-3llJymI6i6JIMzY_cdy0XKoWxn3KINS_qQ_tgXNIYBwLtDkvqPCMRzlsDQKRD68-iVc8z6U2p0W5xxAaM5RQpjhFyoHgv47bSkW2hwnPL5ATs6nweSlZT_TX7z3mwIbdm6qO2PaT-VJFX2mI93hTNQ6Qegb8ahuhn2c40HUelrH3EgDghU1oU0L3F_6jXKgqBR4epc.","tokenExpires":"2024-10-08T14:30:56.517Z","portal":"https://www.arcgis.com/sharing/rest","ssl":true,"tokenDuration":20160,"refreshTokenTTL":1440},"params":{"isView":"true","outputType":"featureService","createParameters":{"name":"survey123_a3fa5ab0290246308c9c15b0bbc5dd8f_results","isView":true,"isUpdatableView":true,"sourceSchemaChangesAllowed":true,"capabilities":"Query,Extract","hasStaticData":true,"serviceDescription":"Feature service view of results for the survey a3fa5ab0290246308c9c15b0bbc5dd8f","editorTrackingInfo":{"enableEditorTracking":true,"enableOwnershipAccessControl":true,"allowOthersToUpdate":false,"allowOthersToDelete":false,"allowOthersToQuery":true,"allowAnonymousToUpdate":false,"allowAnonymousToDelete":false,"allowAnonymousToQuery":true}}},"headers":{}}}}
Oh boy almost looks like it was on then turned off and got orphaned. Umm not sure at this point. You may be able to delete it manually and recreate? If they is production be careful but if testing? Maybe try a rename on the old one first. This could explain your errors.
Sorry I don't know for sure.
