I am trying to disable a popup on aerial imagery (shown below).
I found this post: https://community.esri.com/t5/arcgis-online-questions/disable-pop-ups-on-imagery/td-p/1126382 which says to click on "remove popups," in map viewer classic but this option is not available on my layer:
In map viewer the popup icon is grayed out:
Any help would be appreciated.
@parkcountygis
It looks like you'll need to go to the layers within your Basemap and disable popups for the Metadata layers.
For Aerial Imagery, I would recommend publishing this as a Tile Layer as this will disable any pop-up functionality.
Hello, The OP looks like they want to turn off basemap pop-ups. I'd love a setting to do this as well. I teach with web maps and students click on a point and the pop-up shows Maxar for example. It's not obvious to them to use the right arrow to go to the next pop-up dialog. Even a setting to make sure that the basemap pop-up always shows last in the list would be good.
I also have this issue showing the Maxar popup for an aerial basemap. How do we remove that?
I have the same issue. I want to disable pop-ups when someone clicks on the basemap. Currently this is what pops up when I accidentally click on layers that are not my vector features.
Same problem here - I have no "Remove Pop-up" function in either MapViewer OR MapViewer classic. Republishing the imagery is not a solution since it is not my imagery - it's ESRI's Imagery Hybrid layer. There's already a credit to the sources in the map, so why would ESRI force a pop-up on base imagery? NO ONE WANTS TO READ ABOUT THIS and it is confusing my users.
Update: This is still a problem for me, It has not been solved.
Hi @David_McRitchie , do you have any more information on this? Based on the other comments this is an issue with the esri basemaps. It occurs on all of my maps as well, here is an example where this happens - City of Livingston Snow Plow Routes
@AlixVezina
@parkcountygis Please could you send me the link to the web map you're using in that app? I'd like to take a closer look.
@AlixVezina yes here you go: https://parkcounty.maps.arcgis.com/apps/mapviewer/index.html?webmap=c924a2c4990541438d7db4d60aec2863
Thank you!
@AlixVezina Thank you for your help!!
Bohužel, když kliknu na tyto podvrstvy basemap imagery, vyskakovací okna informují "Tato vrstva není kompatibilní s pop-upy":
Takže nemohu žádné tlačítko deaktivovat, ale vrstvy stále zobrazují metadata v pop-upech. Máte nějaký nápad, jak se jich zbavit? Děkuji!
