Hello,
This is a going to be a long shot, but I am looking for advice or website material anything to help with an issue I have. This is a stormwater ArcGIS Pro issue.
The issue:
- I need to create two new fields (Up_stream and Down_stream nodes) in our established inventory list of stormwater pipe infrastructure. The two new fields (which I have created) in our Pipe layer, needs to be populated to indicate which stormwater infrastructure the pipes are flowing to and from.
- EX. Inlet X (up steam flows to) ------Pipe-----> Manhole Y or Inlet Z (down stream flows from)
- I need to find a way to populate into the two new fields the feature IDs for the To (downstream) and From (Upstream) stormwater infrastructures.
Research question:
- Does anyone have any insight and how to tackle this situation or have ideas where I can look up tutorials etc.
- Has anyone had experience with this? I’m sure we are not the only one out to encounter this type of issue.
Worst case I manually input the feature ID for each pipe segment, but I am sure there must be something to help jumpstart the process.
Thank you an advance 🙂
