Is it possible to make a question read-only once its own answer is 'yes'? I know it's possible based on a previous question's response, but I need the question to trigger read-only on itself.
My form is set up to monitor wood attributes. The initial survey establishes the data baseline for the wood structure and individual wood pieces. After the initial survey, I will change the structure and individual wood attributes to read-only, except for the question asking if the wood has separated from the main structure. If the wood has not separated, then the question remains editable until next year. If the wood has separated, it will remain separated from then on and relevant questions for veg type, wildlife obs, and wracking will appear in the monitoring section of the form. Once wood has separated from the structure, I don't want staff to be able to change the answer to No in future surveys, so I want to make it read-only.
Putting the form expression in the question's read-only column creates a redundancy error. I don't know if the question's response can be evaluated when the survey is opened to automatically make the question read-only.
I've attached a scaled-down version of my survey. I'm using Survey123 Connect ver. 3.18.123 to create the survey.
Thanks.
