I have three surveys that are serving collectively as an asset inventory system (points, lines, polygons). I have my iPhone connected to a Garmin GLO and have added all of the GNSS metadata fields to my survey. However, only the "@geopoint" metadata fields in the point survey will autopopulate using the pulldata function. I understand that not all of the same metadata parameters will apply to the lines and polygons, but I was hoping to at least grab the accuracy, the fix type, etc. (all the specs that show up when you click the satellite icon). It looks like geoshape and geotrace just might not have these metadata fields available - has anyone found a workaround for something similar?
Thanks!
