Good afternoon.
Since yesterday evening, file questions with a relevant expression are not honoring this setting in web forms.
Sample xlxs attached.
Javier
@jvarasanz ,
Thanks for providing the feedback. I can reproduce the issue by using your XLSForm file.
We are working on a fix and will let you know the plan soon.
Hi @jvarasanz , @KenBouchard , @ChelseaRozek ,
The fix to this issue (BUG-000157639) is now available on the Survey123 website https://survey123.arcgis.com.
Thanks again for all your feedback and testing.
Regards,
Zhifang
Same issue here since yesterday!
Ken
Same here, two of our image questions are suddenly set to display none in the web form even when relevant conditions are met. The file question is fine.
@jvarasanz @KenBouchard @ChelseaRozek ,
We had a fix to this issue installed on the Beta website https://survey123beta.arcgis.com , can you please test if it works for your surveys?
Yes! Its working on the Beta website. (For me, can't comment for the other ones)
Affirmative.
Thanks for the quick response on this.
Yes, both of my image questions work on the beta site and the file question remains working. Thanks @ZhifangWang !
I've just wanted to check if this has already been resolved. Everything seems to be working in the beta website, but I haven't noticed anything different in production. Do we need to republish our Surveys?
Kind regards,
Thanks Zhifang.
Everything is back to normal.
Much appreciated,
Buenos dias.
Utiliza la funcion en el Campo Relevant y te funciona en la WEB
selected(${InspectionCheck},'yes')
I am having the same issue but it doesn't involve file or media questions. The relevant expressions are working in the S123 App but not in the browser. I attempted republishing as an entirely new survey with the same results. My .xlsx is attached. Please help!
Hi @FourCornersMapping , try using count-selected(${date_camp_text})>0 instead of string-length(${date_camp_text})>0. Also (count-selected(${date_camp_text})>0 and count-selected(${camp_alternate})>0) in the lower questions. I was able to get the relevant questions to show up in the published survey with that.
More Info
