My survey is set up to calculate a geoshape question with the geometry from a hosted feature layer on the Portal. The calculation appears to work fine while filling out the form (building footprints appear in the map), but I receive a "database error" upon hitting submit.
Any ideas why surveys would not submit when pulling in geometry from a hosted feature layer? Without the pull data geoshape calculation, surveys do submit.
A screencap of my xls form is below. Thank you.
