I'd like to see support for CASE statements in a Definition Query, particularly where the data is in an Enterprise Geodatabase (SDE) with a database engine that does support this sort of query.
@Bud
Sub query didn't work but I just realised I didn't test it against non-versioned data so will give that a try tomorrow.
How'd it turn out?
For our notes, here's an example of your syntax working in SQL Server (the test has nothing to do with ArcGIS Pro):
https://dbfiddle.uk/shBxoaUj
Related post: Definition Query SQL shouldn't autocomplete WHEN to WHENEVER
For what it's worth, your original syntax seems to work fine on Oracle tables in ArcGIS Pro, both on versioned and unversioned tables:
FIELD1 = (case WHEN 1=1 THEN FIELD1 end)
The brackets were just for legibility. They're not a subquery. It works without the brackets too:
FIELD1 = case WHEN 1=1 THEN FIELD1 end
Oracle 18c; 10.7.1 EGDB; ArcGIS Pro 2.6.8
Thanks for that, I hadn't thought to test out wrapping it in a sub query. Will give that a go when I'm back in the office.
I haven't tested it on nonversioned tables either so will give that a go as well to confirm if it's a bug or not.
I wonder if you could post a question on Stack Overflow or DBA Stack Exchange, with details like this:
A long shot:I wonder, is it actually a bug in ArcGIS Pro -- specifically a bug with how it handles definition queries on versioned data? Does it work on an unversioned table?
I ask because I had a similar issue:Using Oracle SDE.ST_GEOMETRY functions in a defection query or attribute table doesn't work -- due to a bug with versioning in ArcGIS Pro. But if I wrap it in a subquery, then it works fine. Or if the data is unversioned, it works fine too.
If you submit a case to support, and it turns out to be a bug, I suspect a bug would get fixed before an idea would get implemented,.
I should add that the idea is to dynamically return the current season rather than having to explicitly set the current season as it changes.
Interesting. I think I get it now. I hadn't seen CASE used that way before.
I wonder why that doesn't currently work in ArcGIS Pro definition queries. If it's native SQL Server SQL, you'd think it would work. I don't see why ArcGIS Pro would treat it any differently than [WHERE] 1 = 1, or some other typical predicate.
We have a dataset with a field that defines the season of operations which is basically the years that a season spans concatenated plus a suffix, i.e. 2022-2023_<suffix>. A season starts in August, hence the month check in my example. That exact query works from SSMS (obviously this means we are using SQL Server) when I query the versioned view or business table, for example:
SELECT Field1, Field2, Field3
FROM SomeTable
WHERE <see previous example>
It does have a predicate because the case statement returns the season code which is then checked against SomeField.
Unrelated, but the notes in this idea might interest you: Training course on SQL in ArcGIS Pro
Example as follows:
SomeField = CASE WHEN MONTH(GETDATE()) >= 8 THEN CONCAT(YEAR(GETDATE()), "-", YEAR(GETDATE())+1) ELSE CONCAT(YEAR(GETDATE())-1, "-", YEAR(GETDATE())) END
Can you give us a hypothetical example?
When I’ve used CASE in Oracle SQL, it’s usually in the SELECT clause in a full-blown query, not in the WHERE clause expression (a definition query essentially being a WHERE clause).
Přihlaste se pro psaní příspěvků, sledování obsahu a další. Jste tu noví? Zaregistrujte se zdarma.
