We have a situation where we have multiple trees being trimmed at one location. We want to have one survey per day, to have multiple locations. Each location will have multiple tree info. So the location should be a repeat for the day and each location should have 1 or more repeats for tree info associated with it.
Survey Date 10-27-20
101 First St
Pine
Alder
103 First St
Oak
Maple
How would we set that up? We would like to know how to set up a nested repeat to match the above example.
Thanks, Elizabeth
Hi Elizabeth,
Yes, this should be possible and the way you based on the workflow.
The parent layer should be the day/date layer with associated fields to the date, user and other detaisl you want to collect related to that day and the crew.
The first repeat related to the parent needs to be a location layer and include a geopoint question and address questions to capture the location and other related data.
The next repeat which will be nested inside the first repeat above (location layer) would then contain the tree information. It would look something like:
parent layer
date
crew
etc
begin repeat - location layer
geopoint question
address details etc
begin repeat - trees table
type of tree
tree details
end repeat
Hope this helps
Regards,
Phil.
Hi @KarimNaguib,
Where do you want the sum() data to be stored, in the nested repeat of the values you are summing, in the parent repeat, or the parent layer? The sum() can only be used outside of the repeat you are trying to sum().
Another way to do this is using a JS function.
Thanks for the quick reply, Philip. I finally got it to work following your example and some trial and error. It was a bit challenging for me because I had groups in the survey as well.
Elizabeth
This is really helpful Phil, thanks. Is there a way to summarize on the data within the nested repeat though? I have a similar survey, but the repeated data are costs rather than tree type/details. I can get an accurate Count(), but when I do a Sum() on the field, it returns what looks like maybe a concatenation of the data rather than a sum. My form is attached (other than external tables). the green section is where I'm having issues, and the blue section is the greater repeat. I even included a hidden field within the repeat to summarize on, then on my summary page, I tried pulling from that hidden field, but it still doesn't properly sum the repeated records. Any insight would be appreciated. Thanks,Karim
Thanks Phil,
I want the sum() data to be stored outside of the repeat. I had a hidden field inside the repeat that I was using to sum on, and then outside of the repeat I was running another sum() on that hidden field. That field was bound as a decimal, but I just moved it to outside of the repeat and it seems to be working now, thanks Phil.
