Caching “Suggestion” option is not available in ArcGIS Pro 2.4.1,
It would be great if the caching “Suggestion” option gets available in ArcGIS Pro
This may be addressed in https://community.esri.com/ideas/14403
Not sure if this is planned to be in 2.6
Implemented in ArcGIS Pro 2.7.
See Ideas in ArcGIS Pro 2.7: Something to Celebrate
Also check out what's new in ArcGIS Pro 2.7!
Not really. The “advanced settings” available in ArcMap is not there in Pro. How scales can be entered as we do in ArcMap?
Not implemented even in 2.9
I've almost left ArcMap, but this is one thing that I still need ArcMap for. To be able to create my own custom tiling scheme. The auto suggest option is implemented in Pro, but without the advanced settings where you can modify the scales it's kind of useless to me.
@KoryKramercould you change status to partly implemented or something? or would it be better to create a new idea for the part where you can type your own scales? I looked for one but didn't find anything.
Hi, it is possible to cache using custom scales. This can be accomplished by using the Generate Map Server Cache Tiling Scheme tool to create a custom tiling scheme that is then imported into the Sharing pane using the Tiling scheme file option in the dropdown.
@MattiasEkström If the above workaround doesn't meet your needs, I agree that this would be better as a new idea. Thanks!
Thanks @SusanTran !
It's another workflow than I'm used to, but it does meet my needs.
I still miss it in the cachning dialog, but that's more of a habit. It's not that common to create a new custom tiling scheme so I can definitly use that tool instead.
Přihlaste se pro psaní příspěvků, sledování obsahu a další. Jste tu noví? Zaregistrujte se zdarma.
