How do you pass nothing to the default location in connect? I am using a pulldata for the exif of an image that will generate a default location to be confirmed in the survey.
I want to set up an if statement to use my generated location or pass nothing and use the default location of the device collecting the survey. It works great as long as I get the lat/long from the image, but I need the else for the cases I don't.
It seems if you pass nothing, the map does not show as normal. And you have to click the to load your location. (see attachment)
