Hello everybody,
I've got this little thing challenging me for a few days now : I'm trying to use the value of a given answer (for instance the answer to "Id_Number", which will be an Integer), and set it as the default value for the next survey. The main idea being that the value of the "Id_Number" in the survey n+1 is likely to be "Id_Number in survey n" incremented with 1.
I know that you can calculate a field based on a previous question, but so far I haven't found any way to calculate a field based on the same question in the previous survey.
Any idea on how to proceed?
Thx in advance,
Al
