1) After saving a template in Manage templates the "Saved Successfully!" message box appears and does not go away. Have to load another tab then go back to the Data to clear the message.
2) Report download does not automatically start after generation when "Save result to your account" is not selected. Saving results works but it's annoying to have to go to another page to download the results.
3) Map generation is failing. Template line of "${EncroachmentLoc | size:300:0}" throws an error:
| Job ID | 24027159b4e94382b89461475bdee8b5 |
| Status | Failed |
| Message | Failed to print map for ${EncroachmentLoc|size:300:0}. |
Removing the line lets the report generate.
4) In a different survey report template that worked last week:
| Job ID | 9697e5d395fb49858d2cd09ff88d67f8 |
| Status | Failed |
| Message | Error occurred when checking the report template. Failed to parse "${ReportDate|format: ’MM/DD/YYYY’}"Field "${ReportDate}" does not exist or cannot be found in current parsing scope. |
