Hi All,
Regarding of the limitations in appearing the attachments of repeat question in Survey123 Website I need to know if there is a way to set a default Map Viewer in (Open in Map Viewer) so the end user can see the attachment of the repeat question in the portal as a temporary solution until the limitations break.
so, please share your ideas if anyone has a workaround solution. James Tedrick Ismael Chivite
