I have a survey form created in Survey123 Connect embedded into an ArcGIS Dashboard. The survey is being used to update existing records in a feature service. The feature service is set to allow features to be updated (but not added/deleted) and the survey is shared with the necessary users.
I (the survey owner) can submit surveys without a problem. When others submit a survey, they get the below error, however the records are still updated with what was put into the survey, even though it says it failed to submit.
.png)
Any ideas on what might be causing this to happen?
