Hi, using build in WAB on ArcGIS Enterprise 10.7.1, I have a date field where I can see the time. However using the edit widget, i can only set the date field.
I saw a post Edit Widget - time not visible when DateTime field has time enabled that suggest fixing it on _convertConfiguredLayerInfos however that code never gets called. It always goes to this._getDefaultLayerInfos(). And I don't think we have exactly the same issue can someone please advise
I am expecting to see which I currently don't.
Robert Scheitlin, GISP hopefully you can help
