Hello
I have ArcGIS Server in Azure, with Survey based on ArcGIS Server Feature service.
the survey and service contains feature layer, attachment table and related table.
I need to replicate this layer into different disconnected network.
I use disconnected replication for that.
The problem is the the feature layer MUST be versioned to participate in replication, while it MUST NOT be versioned to be used in Survey123.
Any ideas what to do?
I've created the layer and related tables non versioned - for the survey.
I tried to create "shadow" layer and tables, versioned - for the replication.
Now the problem is how to sync them?
Building SQL triggers between them is very complicated, and I'm not sure I'll be able to create the relationship between the layer and tables in the versioned copy.
Any ideas for that synchronization?
Thanks in advance
Ofra
Systematics
