Dear ESRI TEAM,
Regarding measuring time in second the Excel sheet attached by James indicates that second can not be measured directly in survey123 is there a way to generate second because the attached excel not clear for me !!
because i use " ${task_order_organization_code} + '-NTS-' + format-date(${nts_date},'%Y%m%d') + '-' + format-date(${nts_time},'%H%M') " for ID reports to not get duplicate ID but now i see if two field reporters open the survey at the same time we will get duplicate ID so we need add second for ID as well to not get duplicate ID.
any suggestion it will be appreciated
