survey123survey123_connect_for_arcgis survey123 geopoint
Hi.
I am trying to publish a survey using Survey123 Connect for ArcGIS which will be used to identify unsafe areas for pedestrians. I would like to use my organisation's custom locator service to perform the location search instead of the ESRI World Geocoder.
In the form preview within Survey 123 Connect, the search bar in the geopoint window matches my organisation's locator service. However, when I publish the form to the Survey 123 website, my geopoint tool defaults to a global view and uses the ESRI World Geocoder.
Is there a way to configure the geopoint search bar either on Survey 123 Connect or the website? My survey is fairly uncomplicated, so I don't have much of a preference. I have managed to get the mapping functionality working in the ArcGIS online Geoform application which uses a webmap, but I would like to use Survey 123 for the added user entry functionality.
Any help is much appreciated. Thanks.
