I have had to do an update to a form, which requires adding some questions to several repeats. It is stalling on the republish.
I've found this:
- Republishing a survey will cause it to stop responding if you have only added a new question to a repeat. As a workaround, you can add a new question outside of the repeat, and then republish. The new question added outside of the repeat will also need to be deleted from the feature service afterward if not needed.
Repeats—Survey123 for ArcGIS | ArcGIS
I'm finding this a bit vague on how to get it to work, any further advice would be seriously helpful.
I'm working in Survey123 Connect v3.3.51 (updated today) on MacOS
Thanks in advance.
