I am creating a survey with Survey123 for Portal, I turned off the setting for "Use global id parent keys in repeat relationships" which I was informed was a limitation within Portal. This resolved the issue I was having will submitting my survey.
Now I would like to export my data to .csv for further analysis outside of Portal, however when I download the data I get the following fields:
Parent table:
objectid
globalid
rowid_ (This value is blank)
username
created_date
created_user
last_edited_date
last_edited_user
x
y
Child (repeat table):
objectid
globalid
repeatquestion1
repeatquestion2, etc.
parentrowid
created_date
created_user
last_edited_date
last_edited_user
It seems to me that the rowid_ field and the parentrowid field should be the key field, however the rowid_ field in the parent table is blank. The parentrowid field in the child table is populated, but I am not sure how to relate that back to the Parent table.
I have been submitting test surveys to the Portal using the Survey123 for ArcGis Windows app.
My proposed work around is to use a combination of the created user and date to create a unique key to match across tables, but it seems to me that the program would need to have some field for this already in order to be able to know that there are related records to display.
Am I doing something wrong, did anyone else have this problem, or does anyone have any advice? All help is greatly appreciated.
JTedrick-esristaff
