Is it possible to calculate a GUID type field with a value of my own design? I can create a string of the specified dimensions with my own string + blank spaces and brackets:
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'tv'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
oid <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
select <SPAN class="operator token">=</SPAN> <SPAN class="string token">'OBJECTID = {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>oid<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"tv"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN>select<SPAN class="punctuation token">)</SPAN>
length <SPAN class="operator token">=</SPAN> len<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
target <SPAN class="operator token">=</SPAN> <SPAN class="number token">36</SPAN> <SPAN class="operator token">-</SPAN> length
value <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>ljust<SPAN class="punctuation token">(</SPAN>target<SPAN class="punctuation token">,</SPAN><SPAN class="string token">' '</SPAN><SPAN class="punctuation token">)</SPAN>
value <SPAN class="operator token">=</SPAN> <SPAN class="string token">'{'</SPAN><SPAN class="operator token">+</SPAN> <SPAN class="string token">'{}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>value<SPAN class="punctuation token">)</SPAN>
value <SPAN class="operator token">=</SPAN> value<SPAN class="operator token">+</SPAN><SPAN class="string token">'}'</SPAN>
<SPAN class="keyword token">print</SPAN> value
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>
<SPAN class="punctuation token">{</SPAN>BC_00<SPAN class="number token">.61</SPAN> <SPAN class="punctuation token">}</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>But when I plug in a arcpy.FieldManagement() method instead of the print in line 11, I get the famous error # 999999: 'generic error'....
