Just saw today that Collector now can see offline device data from Tracker.
View local tracks from Tracker for ArcGIS
If you record your location using Tracker for ArcGIS, now you can view those tracks inside of Collector. If you tap on the Layers tool you will find a new entry titled “My Tracks” and you can tap on Tracker to open the Tracker app to turn on/off tracking or adjust the history of tracks to display. Collector displays the tracks that are stored on your device so you can see previous locations even if you lose connectivity. It will honor the display settings from Tracker as well so if you only want to see Todays tracks in Collector, set Tracks to Display to Today in the Tracker app.
Any plans to open up the 123 database on the device to Collector?
My use case is we have 9 forms (with 2 of those needing 3 transects) that need to be completed on a plot. I have some Arcade code that checks for each form or forms and then reports back to the user in Red that they missed one. This works in the web map great. But it does not work in Collector while offline for two reasons. One is that I am offline so Collector has no idea what 123 has in its DB. Two is the FeatureSetByName does not work while offline - yet. They told me FeatureSetByName would be working around the end of 2019 but I have not seen it yet.
My issue is that by the time they are back online it is too late. Most of our cost is travel to the plot so having to go back is a major expense. We are looking at a low tech dry erase sheet at this point.
For now we have a group trying to build there own app using the 123 API to dig in the 123 DB while offline.
BTW any thoughts on auto listing any offline basemaps Collector has in 123?
Really excited to see progress on the apps working together more.
Here is my Arcade as an example. 1 simple and 1 more complex.
LPI Lines Check <SPAN class="punctuation token">{</SPAN>expression<SPAN class="operator token">/</SPAN>expr1<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>$feature<SPAN class="punctuation token">.</SPAN>EvalStatus <SPAN class="operator token">==</SPAN> <SPAN class="string token">"Eval"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
var sql <SPAN class="operator token">=</SPAN> <SPAN class="string token">"PlotKey = '"</SPAN> <SPAN class="operator token">+</SPAN> $feature<SPAN class="punctuation token">.</SPAN>PlotKey <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'"</SPAN><SPAN class="punctuation token">;</SPAN>
var tbl <SPAN class="operator token">=</SPAN> <SPAN class="token function">Filter</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">FeatureSetByName</SPAN><SPAN class="punctuation token">(</SPAN>$map<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"LPI"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> sql<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
var txt <SPAN class="operator token">=</SPAN> <SPAN class="string token">''</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN>var f in <SPAN class="token function">OrderBy</SPAN><SPAN class="punctuation token">(</SPAN>tbl<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"LineNumber"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
txt <SPAN class="operator token">=</SPAN> txt <SPAN class="operator token">+</SPAN> f<SPAN class="punctuation token">.</SPAN>LineNumber <SPAN class="operator token">+</SPAN> <SPAN class="string token">' '</SPAN>
txt <SPAN class="operator token">=</SPAN> <SPAN class="token function">Left</SPAN><SPAN class="punctuation token">(</SPAN>txt<SPAN class="punctuation token">,</SPAN><SPAN class="token function">Count</SPAN><SPAN class="punctuation token">(</SPAN>txt<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>txt <SPAN class="operator token">!=</SPAN> <SPAN class="string token">'1 2 3'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="string token">"\n----LPI Line Number Issue! Found: "</SPAN> <SPAN class="operator token">+</SPAN> txt
<SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="string token">''</SPAN>
Spec Rich Count <SPAN class="punctuation token">{</SPAN>expression<SPAN class="operator token">/</SPAN>expr2<SPAN class="punctuation token">}</SPAN>
var tbl <SPAN class="operator token">=</SPAN> <SPAN class="token function">Filter</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">FeatureSetByName</SPAN><SPAN class="punctuation token">(</SPAN>$map<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"Species Richness"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> sql<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
var tblCnt <SPAN class="operator token">=</SPAN> <SPAN class="token function">count</SPAN><SPAN class="punctuation token">(</SPAN>tbl<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>tblCnt <SPAN class="operator token"><</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="string token">"\n----No Species Richness form found!"</SPAN>
<SPAN class="keyword token">else</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>tblCnt <SPAN class="operator token">></SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="string token">"\n----More than 1 Species Richness form found!"</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
