I'm not sure if this is by design or not, but I am noticing that the Survey123 Sync settings (when publishing a Survey123 form) are not being honored on the item page in Portal.
According to this page (Publish your survey—Survey123 for ArcGIS | Documentation ), you can choose to either enable or disable sync when publishing a Survey123 form. However, when I publish a Survey123 form to Portal with sync disabled, on the Survey123 hosted feature service item page, it has sync enabled regardless if I choose to enable it or not.
The documentation I linked above leads me to believe that if I choose to disable sync when publishing a Survey123 form, it will be unchecked in Portal because the documentation states that I can enable it at a later time via the settings tab on the item page. However, it's checked as being enabled regardless if sync is enabled or not.
Is this normal behavior or am I just missing something here?
I'm using Survey123 Connect 3.6.137 and ArcGIS Enterprise 10.6.1.
