I am working on a project that will allow some agency biologists to use S123 during aerial surveys tracking Florida panthers. I can load the survey onto the iPad Pro, and use it without a problem. Because the biologists won't have access to a cell signal in the center of the Everglades, I have created a TPK file and added it to the iPad using the instructions found in Prepare basemaps for offline use ;I used iTunes to transfer the file. I can see the TPK file in the Geopoint question, so I know S123 can read it. The problem lies when I try to submit the survey. Nothing happens when I click "Send now" and "Save this survey to the Outbox". Something happened in the background when I upload the TPK file. Other surveys operate correctly. Thinking I messed-up the upload of the TPK file, I deleted the app, then reinstalled it, downloaded the panther survey, opened it, and was able to submit a record. I then added the TPK file using iTunes, and tried the survey and ran into the previous problem. To see if the iPad Pro was the problem, I tried adding the survey and basemap onto an older iPad and obtained the same results before and after adding the TPK file.
I am attaching a copy of the survey.
Any help you can provide is greatly appreciated.
Chris Anderson
Florida Fish and Wildlife Conservation Commission
Fish and Wildlife Research Institute
