I want to be able to make a field required based on the answer in another field.
e.g. If a house has damage after a storm answer the damage type field.
You don't seem to be able to use calculations like: ${House_Damaged} = 'Yes" in the required column like you can with relevant.
Is that correct? We're collecting damage assessments and we have a whole bunch of fields that are only collected if the house is recorded as damaged. We do collect non-damaged buildings around the edge of an event to show the edge of an event.
