All - we are currently experiencing an issue where data are loading very slowly within AGOL. It sometimes indicates that there are 2000 features in the dataset and sometime indicates there is the correct number (459 in this case). If the data tab loads within AGOL, there are no attachments associated with any row. I've tried loading the same dataset in survey123.arcgis.com and it either indicates there is no data associated with the survey or locks up when trying to load the dataset.
Is this a server issue that is currently being experienced or is there an issue with the data? This has occurred with 3 separate surveys so hopefully a server issue.
Chris
