Is there method to change the pop-up window size in WAB Developer Version? The pop-up window is set up in the web map, then the web map is set up in WAB Developer Version. The pop-up window content can be controlled but it does not allow users to change its size. What if I want to make it bigger? Should I go to search anywhere in jimu.js folder? Thanks!
