I have a couple of JS applications that used to work very well. After several months, I re-run them again and got problems in adding symbols on the map. The related code is below:
function drawResponseGeometries2(response) { map.graphics.clear(); // clear graphicsLayer if exists var pointJson = response.Geometry[0]; var point = new esri.geometry.Point(pointJson); var symbol = new esri.symbol.SimpleMarkerSymbol({ "color": [255, 0, 0, 128], "size": 10, "angle": -30, "xoffset": 0, "yoffset": 0, "type": "esriSMS", "style": "esriSLSSolid", "outline": { "color": [0, 0, 0, 255], "width": 1, "type": "esriSLS", "style": "esriSLSSolid" } }); var g = new esri.Graphic(point, symbol); map.setExtent(initialExtent.expand(0.125)); map.graphics.add(g); map.centerAt(point); }
When I run debugger, I could not detect anything wrong. How can this program be debugged? Appreciate if you can share your experience.
Remark: The new format of this forum looks to be not good at all.
