I have the ArcGIS Pro 2.2.1 with all the features installed. I am trying to create space-time cube using the tool, however, when I try to run it, I get this error: Error 001022: This tool requires a projected coordinate system.
I have defined both "Current XY" and "Current Z" coordinate of the map (Utah; as can be seen attached) to GCS North American 1983 and NAD 1983 respectively, so I have no idea why I get this error again and again. Do you have any idea?
Moreover, I have also used the "Project" tool to project the Layer (Utah_Zipcode_Time) that I want to use in the "Create Space Time Cube" tool. This is a shapefile with a time-based variable, count of incidence, and many other variables in it.
.png)
.png)
