When I'm running Snap Pour Points tool for a set of 15 points on a flow accumulation raster, it's hanging after getting to 100% on the progress bar for the "Snapping pour points..." step. All 15 points were generated from certain portions of the stream line generated from the sane flow accumulation. I'm needing to do this because though 13 points are well located, 2 of them are just off the stream accumulation raster cells, so I'm needing to snap them over a bit to get proper watershed analysis. The Snap Pour Point tool is consistently hanging whether running with 15 points or 1 point. I'm using a Snap Distance of essentially the width of 2 - 10m raster pixels (20 meters or 62 feet).
After cancelling the hung process from the status window, an unhandled crash exception occurs and I used that tool to send the crash dump data and referenced this discussion thread title for context. The Errors that I see presented in the status window before it crashes are as follows:
ERROR 999999: Error executing function.
The table was not found. [VAT_KeyPointsSnapRaster]
A column was specified that does not exist.
ERROR 010017: Operation has been cancelled.
ERROR 010296: Error in writing raster C:\Users\jamie\Documents\Education\GIS\501-Capstone Project\Scratch.gdb\KeyPointsSnapRaster.
ERROR 010067: Error in executing grid expression.
Failed to execute (Snap Pour Point).
Failed at Fri Jan 17 12:08:57 2020 (Elapsed Time: 4 minutes 5 seconds)
snappourpoint hydrology watershed
