I'm not a Python expert so I'm wondering if my script is already the most efficient way of doing this or if there's a better way. We have a table in SDE (SQLServer2012 back end FWIW) and we're running a Windows Task scheduled service to pull records from an Access Database over to the SDE table every 15 minutes. Because the table is providing content to a web map, I cannot delete the table (at least I don't think I can without affecting the web map). For this reason, I chose to develop a script that empties the table of all records and then inserts the updated records. Usually, we're talking about 2800-3400 records at any given time.
Digging through my script, I'm seeing that the initial step of deleting the existing records is taking *much* longer than the task of copying records from the Access database into the SDE world. I'm quite shocked by that; I suspected that the reverse was true. Here is my script:
import sys
import os
import linecache
import logging
import arcpy
import time
from datetime import datetime
from arcpy import env
file01 = r"\\pmc-floodwatch\DIADvisorDatabases\DvLive.mok" #This file must exist
file02 = r"\\pmc-floodwatch\DIADvisorDatabases\DvLive.mno" #This file must NOT exist
expression = '1=1' #SQL shorthand which select all records
theTable = "SPW_GIS_PROD.SPW_GDBA.HYDROGRAPHY__tblGageData"
#Establish the error log file
logger = logging.getLogger('errorLog')
hdlr = logging.FileHandler(r'\\python\errorLog.log')
logger.addHandler(hdlr)
# The tables within DIADvisor must not be accessed during its daily database maintenance.
# OneRain recommends checking for the existence and non-existence of two specific files.
# If both conditions are true, it is safe to proceed with connecting to the data within
# the dvLive Access database
if os.path.exists(file01) and not os.path.exists(file02):
print "=================================================="
print "Processing start time: " + str(datetime.now())
print "==================================================" + "\n"
env.workspace = r"C:\Users\spwscc\AppData\Roaming\ESRI\Desktop10.3\ArcCatalog\SPW_GDBA@SPW_GIS_PROD@SQL2012-SQL127.sde"
try:
# Set some local variables
tempTableView = "gageTableView"
# Execute MakeTableView
arcpy.MakeTableView_management(theTable, tempTableView)
# Execute SelectLayerByAttribute to select all records
arcpy.SelectLayerByAttribute_management(tempTableView, "NEW_SELECTION", expression)
print " * Deleting existing records in SDE: " + str(datetime.now())
timeDelStart = time.time()
# Execute GetCount and if some records have been selected, then execute
# DeleteRows to delete the selected records.
if int(arcpy.GetCount_management(tempTableView).getOutput(0)) > 0:
arcpy.DeleteRows_management(tempTableView)
timeDelEnd = time.time()
timeDelElapsed = timeDelEnd - timeDelStart
print " Time elapsed: " + str(timeDelElapsed) + " seconds" + "\n"
# Now connect to the DIADvisor access database and import the most recent data
# This requires the OLD DB connection previously established using ArcCatalog
counter = 0
print " * Starting record transfer from DVLive: " + str(datetime.now())
timeStartTransfer = time.time()
accessRows = arcpy.SearchCursor(r"C:\Users\spwscc\AppData\Roaming\ESRI\Desktop10.3\ArcCatalog\jetConnectForDvLive.odc\last3days")
curSde = arcpy.InsertCursor(theTable)
# Loop through the results returned via the OLE DB connection
for cRow in accessRows:
curSensorId = cRow.sensor_id
curEpoch = cRow.epoch
curData = cRow.data
curDataValue2 = cRow.dataValue2
counter += 1
#Insert a new row into the SDE table with the current DIADvisor record's information
row = curSde.newRow()
row.SENSOR_ID = curSensorId
row.EPOCH = curEpoch
row.DATA = curData
row.dataValue2 = curDataValue2
curSde.insertRow(row)
timeEndTransfer = time.time()
timeTransferElapsed = timeEndTransfer - timeStartTransfer
print " Time Elapsed: " + str(timeTransferElapsed) + " seconds" + "\n"
# We're done so perform some variable cleanup
del row
del accessRows
del curSde
del cRow
print "Processing end time: " + str(datetime.now())
print "Number of record(s) in the DIADvisor database: " + str(counter) + "\n"
except Exception as e:
# If an error occurred, print line number and error message
exc_type, exc_obj, exc_tb = sys.exc_info()
fname = os.path.split(exc_tb.tb_frame.f_code.co_filename)[1]
theMessage = "\n" + 80*"#" + "\n" + 80*"#" + "\n"
theMessage = theMessage + "DATE/TIME: " + str(datetime.now()) + ":" + "\n"
theMessage = theMessage + "EXECPTION: " + str(e) + "\n" + "\n"
theMessage = theMessage + "CALLBACK TRACE: " + "\n"
theMessage = theMessage + 20*" " + "File: " + str(exc_tb.tb_frame.f_code.co_filename) + "\n"
theMessage = theMessage + 20*" " + "Line " + str(exc_tb.tb_lineno) + ": " + str(linecache.getline(exc_tb.tb_frame.f_code.co_filename, exc_tb.tb_lineno))
theMessage = theMessage + 20*" " + "Exception Type: " + str(exc_type)
print theMessage
logger.error(theMessage)
else:
sys.exit()In terms of runtimes, here's a quick sampling:
================================================== Processing start time: 2015-12-16 12:49:01.322000 ================================================== * Deleting existing records in SDE: 2015-12-16 12:49:03.491000 Time elapsed: 66.4879999161 seconds * Starting record transfer from DVLive: 2015-12-16 12:50:10.022000 Time Elapsed: 4.12600016594 seconds ================================================== Processing end time: 2015-12-16 12:50:14.157000 ================================================== Number of record(s) in the DIADvisor database: 3167 >>> ================================ RESTART ================================ >>> ================================================== Processing start time: 2015-12-16 13:00:50.661000 ================================================== * Deleting existing records in SDE: 2015-12-16 13:00:53.012000 Time elapsed: 71.2430000305 seconds * Starting record transfer from DVLive: 2015-12-16 13:02:04.295000 Time Elapsed: 4.01099991798 seconds ================================================== Processing end time: 2015-12-16 13:02:08.314000 ================================================== Number of record(s) in the DIADvisor database: 3173 |
So- am I already clearing the contents of my SDE table in the most efficient way possible or is there a better way?
Thanks!
Steve
