I have seen a couple forum posts dealing with this issue but no resolution. I have created a custom step in Workflow Manager 10.3 to reconcile and post versions however I get an error that the input database connection is not correct. If I browse to the input database and add it the dialog box does not change but the error goes away and the tool will run. So it appears that I have set the custom step up properly in WFM Administrator but when I run the step in WFM I get the error.
Help is greatly appreciated.
