I'm trying to use Survey123 Connect to create a new survey from a feature service. The feature service is a geodatabase with 3 tables and established relationships between them — 1 parent table with 2 child tables. I created the geodatabase and set the relationships in QGIS before exporting to .gdb and uploading into ArcGIS Online.
When looking at the item in AGOL, all of the tables are correct in the Data tab and all relationships between the tables are intact. When I create the survey, the fields from each table populate the .xlsx file and seem to each appear in the appropriate format (fields for related tables appear in repeats). Even though it seems that even Survey123 Connect identified all of the relationships correctly, attempting to publish the survey gives me this error. The field in question is an ID field in a child table, which is the field that relates to the parent.
Does anyone know how to resolve this? Do I need to use global ID's instead of the relationships I setup?
Thank you!!
