I want to use the point overlay style described here - Point overlays on maps - to make repeats of geopoints more user friendly.
This works great in the Survey123 Connect app - as I add more points to my repeat, I can see the previously entered points. However it does not work in the Survey123 Web version of the form. Can someone confirm that this is a limitation of the web form?
The help doc says that "Geopoint symbology." is not supported by the web app but I am using the default symbology. Point overlays is not in the list of unsupported functionality.
If this functionality is not supported, has anyone figured out how to make a geopoint question in a repeat more user friendly? In particular, I'd like the extent of each geopoint map in the repeat to be consistent.
When the survey opens, the map defaults to the entire of Illinois. Users will be entering a cluster of points. When the user zooms to their area of interest in the first repeat, I'd like subsequent repeats to default to that first extent. Has anyone figured out how to accomplish something like this?
Thank you!
