Hi!
I am working on an existing Experience Builder application and was playing around with the Widget Controller. I added a Button Widget to the Widget Controller and used Set Link to link it to a window called, Map Tips. Whenever I test this button out within the Widget Controller, it doesn't open my linked window. Is there something I am missing in the settings? I know there is a bug issue that has to do with the Hover settings, but I don't have my button set to change at all if you hover over it. I have a similar Button Widget that is not within a Widget Controller, and it works as expected when it is linked to open a window. Below is a screenshot of my current settings for the button within the Widget Controller. And another screenshot showing what should open if the linked window was working on the button located within my Widget Controller. Instead, all I get is the red pop-up window. Any help would be greatly appreciated!
Bec
Button settings for Button Widget witin Widget Controller
Linked Window that should open, but doesn't.
